Old 01-24-2010, 01:25 PM   #11
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
That kit looks great--wish I had found it before I got my gasket job finished.
If your cyl. head bolts were really only had tight, I don't think there's any way the gasket could survive. What torque did you use when you retightened them?
Here's the problem--the gasket leaks either between cyls. or cyl. to water passage. The engine will still run, but it will use water/coolant and tend to run hot. Coolant will get into the oil, which is bad for the crank bearings after a while. The hot combustion gasses will slowly cut gouges in the head and block, eventually ruining them.
I didn't see any white water/sludge in your photos, so you might luck out.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
