Old 01-20-2010, 02:49 AM   #11
I know where you meant... is the rubber O-ring still intact? Did you back the regulator out further and then try retightening the nut? If you're getting fuel out of the top of the nut then the seal below is failing... only place i can see where that could happen (I'm looking at one right now).
