Old 01-15-2010, 01:00 AM   #1
Originally Posted by 916MKIIIx2 View Post
If you run the vacuum hose correctly the air flow sensor will pick up the air flow changes and there should be no stutter from the engine when letting off the gas from hard accel, learned from doing it wrong the first time ;p
WTF? You've just DUMPED a large quantity of air. The 7M doesn't use any sort of meter which can see this loss... thus many people experience problems. And vacuum has nothing to do with it at all... Interestingly some people just see heavy richness and some occasional backfiring (postignition). If you have a fuel controller this can usually be compensated for.
