Old 01-11-2010, 10:16 PM   #1
TonkaTim
TonkaTim is on a distinguished road
http://www.cygnusx1.net/supra/TechTi...ror_codes.aspx
(for a 91 model, but still might be of use)
51 Switch Signal Diagnosis
  • No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
  • A/C switch circuit
  • A/C switch
  • A/C amplifier
  • Throttle position sensor circuit
  • ECU
Green,
Thanks for the quick reply. I was on that site and missed that page. Was looking at the codes here http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=28 .
Sun is starting to drop so it'll be getting cold & dark fairly soon for me. So I need to go find my ohm meter and check the reading on the TPS tommorow.
I take it no idle signal on the TPS may prevent the computer from letting the car start? (never had a TPS problem on any car I've owned)
TonkaTim is offline   Reply With Quote
