Old 01-11-2010, 01:19 PM   #1
Green7mgte
Supra Forum Moderator
first time oil change.. Add.. check, add check.. add check.. write it down. I have a running sheet were I record all maintance and mechanical work I do. ez referance for how much oil I added last time.. or sometimes I even mark it on a peice of tap to the inside of my door. don't worry about it if you add to much, just drain some out, since you have it on jacks anyhow. Do not run your car with too much oil. I did this once on a 89 sunbird, I made it 1/4 mile down the road when my gauges went fish eyed and my car shut off. My 7mgte takes at least 5 quarts
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
