Old 01-06-2010, 08:48 AM   #2
Please do not create multiple threads for the same problem. It makes it harder for us to help you as it is harder for us to know what you have tried and what precisely is going on with the car.
I'll merge this thread with your other one.
Meanwhile check the ground wire running to the coilpacks for deterioration and corrosion. Check the ground wires which connect to the head on each side. Check for stored diagnostic codes. I'd also go and replace the EFI fuse, even if it looks good.
