Old 01-04-2010, 04:26 AM   #1
Green7mgte
Supra Forum Moderator
my 7mgte also has an exhaust leak. after the head was rebuilt I had just about everything in place and realized i had a stripped and F that noise of Undoing all the work. an exhausting 3 days. so I came up with a solution of getting a concrete lag bolt that would seal up my hole. either that or remove the head, tap, re assemble. which im prolly going to do anyhow. but with the lag bolt I would not need to remove my entire head. sorta a quick fix.
a side note.. exhaust leaks left unchecked will burn up the head and valv cover gaskets over time. my 2 cents on the rebuild or swap. the break down and repair of your 7m will be time consuming, expensive. I would suggest checking the integirity of the remaning moter to even see if its repairable then make a decision. think of what is going to be needed in the rebuild and assign it a value based on how important it is to you. the higher the importance the higher the number.. Money, is this important? if so assign it a high number. time? how important is that.. assign it a number.. (1-20 works) manual labor.. things of this nature. now do it for the 1jz swap and see wich has the higher numarical value. go with the lower one.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
