Old 01-03-2010, 07:07 PM   #11
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
ok so my friend says that the smoke is nothing. grrr
"keep trying"
ok so. lets think this through again. the cam gears should be pointing up as the crank is at 0. right?
i take the cap off the dist.... sh*t as i was reading i was going over cre's other post.
"Line up circle indicator with notch on the other end."
circle indicator? that little hole inside the dist?
i lined up that little notch with the other little notch on the side...
God im hopeless
cvbikeguy is offline   Reply With Quote
