Old 01-01-2010, 10:13 PM   #2
Green7mgte
Supra Forum Moderator
I never change my drain plug when I coolant flush. seems a bit finicky to me. if your sure that's were your slow drip is coming from, is your car under pressure ? or is it constant but visible under pressure? I would shell out the 10 dollars and buy a new plug before renting a rad pressure tester. I bought one cause I like toys. that will confirm or deny your plug issue.
pliers hu? also seems a bit overkill to me. Hand tight should do the trick. possible you messed up gasket or the threads tightening that plastic screw so tight. purchase both replace. If you still see a leak rent a tester and confirm it.
/edit oops. its not your computer. i deleted the post my mistake../edit
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
