Thanks Ill check both of those the center bearing has at least 1/2" of play you can almost touch the top and bottom not quite a little exageration. It clanks real bad when you go from p or n to drive or rev. So it needs changing anyways and Ill recheck my marks I made didnt have white out so I used wifes fingernail polish and it was harder to see than I thought so thats a possibility although Im pretty sure I got it never hurts to double check. Thanks to you to Cre, Ill def check that out cause It kinda slid a little out and I slid it back in I dont think it moved but I thought it was just one way.
1987 Supra 7MGE - Auto - Stock - White
Previoius Toyotas;
1992 Toyota Celica Gt, (Sold)
1988 Toyota Celica Alltrac Turbo (Died)
