Old 12-25-2009, 02:55 AM   #1
Originally Posted by suicidal View Post
he is apparently a supra guru and he was saying change the tranny fluid
He is an idiot if he thinks the gear oil is going to affect the slave cylinder not moving far enough. I just love it when someone meets a supra guru.... he's not from Texas is he?
EDIT: Just saw you mentioned "stage 2 clutch" in your sig... is this whole setup new? If so, specifically what clutch kit did you install and what was in to begin with? Up graded clutches generally require more foot pressure and don't slip as readily as OEM. (Changing gear oil still has nothing to do with this... although it's not a bad idea in its own right. )
