Old 12-24-2009, 01:38 PM   #1
Cameroonski
Cameroonski is on a distinguished road
I'm not seeing how you came to the conclusion that a damaged e-brake is out of the question... it's the most likely problem unless you're not telling us everything (like the part where you slide sideways into a curb).
You said 1986, is this a MKIII (1986.5) or a MKII Supra? I moved this to the MKIII section assuming 1986.5 but realize I may have placed it in the wrong section.
Yes it's an '86.5 MKIII. Thank you. I didn't hit anything, but I guess it would make since that the E-Brake is damaged. I was going almost 40mph, so that could be it. The car couldn't get much over 40 after I did it, and I haven't driven it since it happened. I'll take a look at that. Thanks
Cameroonski is offline   Reply With Quote
