Originally Posted by Cameroonski
I recently bought a 1986 Supra, and I was having fun with it in a parking lot. I did a 180 turn with the E-Brake, and after that it felt bad. It was like it was having a really hard time going. I revved the engine in neutral, and it's fine, so it's gotta be something else. I don't think the E-Brake is sticking, b/c the car rolled just fine from a stop. So maybe its the alignment or something in the limited slip went out?
Please Help!
I'm not seeing how you came to the conclusion that a damaged e-brake is out of the question... it's the most likely problem unless you're not telling us everything (like the part where you slide sideways into a curb).
You said 1986, is this a MKIII (1986.5) or a MKII Supra? I moved this to the MKIII section assuming 1986.5 but realize I may have placed it in the wrong section.
