Old 12-22-2009, 06:20 PM   #1
discord
discord is on a distinguished road
i did a visual check of the harness before installing. I didnt unwrap the the wire loom tho to check inside. I will check the ignition switch as well as try to get power to the ecu. I am also suprised that only b1 is getting power and not the other two. your right, sounds like a wiring problem. when I hoocked up my multi meter to those other 2 the voltage actually showed a negative of about 1.5v on both. not sure what that means...thanks much cre for your input.
1991 supra targa turbo
full rebuild, garrett turbo, chrome header, custom made adjustable wastegate and matching bov, elec fan, hks evc pro, greddy turbo timer, hks 2.0mm hg, arp head bolts, arp rod bolts, 2.5" intercooler and piping, lexus ls400 MAF. AC, power steering, and clutch fan deleted.
discord is offline   Reply With Quote
