Old 12-19-2009, 03:25 PM   #3
MA70-3.0GT
MA70-3.0GT's Avatar
If you take a bit of time to properly read through the tsrm links cre provided you'll find it answers your questions... More haste = less speed as they say, stop trying to rush through without researching properly as I suspect you're doing & you'll find it's a half hour job!
If I'm honest the isc test is one you can usually skip provided you can hear it resetting (clickclickclickclickclick) after engine switchoff, just make sure it's clean inside & the one way valve isn't held open by any bits of rubbish...
EDIT-: and I assume you have no codes stored? That's obviously the first thing to check.
