Old 12-13-2009, 12:48 AM   #1
steves 86 supra
steves 86 supra is on a distinguished road
you can reuse your head bolts as long as there not pitted
to retorque your head back each bolt off about a quarter of
a turn before you retension it, make sure you drop the coolant first
you will find an engine drain bung at the back of the block behind the
turbo,
i had a head gasket start to leak on my old NA motor about 1500 Ks
from home, retorqued it out the back of a servo & ended up putting
about another 50K on it while i built the turbo engine
ps dont use your tension wrench to back bolts off !
steves 86 supra is offline   Reply With Quote
