Old 12-12-2009, 07:50 PM   #1
Are you looking to use this on the stock manifold? Make sure you can find a TPS that can be wired to work with minimal effort too.
It's going to take some work to get it to mount to a stock 7M-GTE manifold. You should contact the seller and get the bolt pattern to make sure it's compatible with your manifold unless you're able to make an adapter plate or pay to have one built. It also will require some modification to get the throttle connected. The stock TB uses a linkage assembly to get around the fact that the cable comes from the intake side. With this you'll either need a long cable with a pretty heavy bend in it, OR you could go to a shorter cable and a custom bracket mounted to the intake side of the head.
Personally, I'd spend my money on other mods first, then worry about the TB. If the pulley was eccentric I would probably be interested though.
