Old 12-10-2009, 08:04 PM   #22
2Fast2Furious
2Fast2Furious is on a distinguished road
My water reservoir never warms up is this right?
I drained the radiator and the coolant was cyrstal clear (pink yes).
I think the engine plug bolt head has been snapped off before because were it should be there is a screw headless bolt hanging out (maybe I'm mistaken and can't find it from top view).
Should I disconnect the hose at the rear them to drain the engine?
The water from the reservoir never drained when I drained the radiator, is this because the pump pumps it out?
Next I filled radiator with water, switched engine on, no change to reservoir, so I undid the plug a little and waited while some water drained, no change to reservoir. How can I get pump to pump water from reservoir to see if it is working?
The radiator gets very hot, I know this is normal but it steams alot. Is this a sign of a leaky radiator or a bad radiator? Why does my thero also read normal?
2Fast2Furious is offline   Reply With Quote
