Old 12-08-2009, 10:46 PM   #35
2Fast2Furious
2Fast2Furious is on a distinguished road
there is no valve cover gasket mentioned on the Toyota document as you can see;
I will ring Toyota tomorrow for more details, like ph etc;
this is were the leaks are according to first mechanic;
are there 2 valve cover gaskets?;
when replacing the valve cover gasket will I have to do a valve adjustment;
these seals are they spark plug tube seals or what about them;
do I need to order 2xseals for gaskets?;
what about grommets?;
what tools am I likely to need?;
should I use sealant and what type?
2Fast2Furious is offline   Reply With Quote
