Thread: Turbo Problem
Old 12-05-2009, 02:46 AM   #6
dunewarz
dunewarz is on a distinguished road
You are dead wrong.... the CT-26 uses and internal wastegate. The wastegate actuator is the round metal can with the rod coming out that is mounted to the CT-26.
BOVs do not vent from boost; They vent when the actuator sees vacuum. They are not a device for controlling boost levels.
Cyto, wastegate actuators are generally not cheap. I would start with trying to find a used one to swap in. Have you actually tested the wastegate to see if it is likely that it's sticking?
Actually BOVs do vent boost. Waste gates prevents boost from occurring by venting exhaust gas from the turbo fin.
dunewarz is offline   Reply With Quote
