Old 12-04-2009, 07:57 PM   #11
If going turbo, I would definitely avoid boring the block unless it is absolutely required.
I recommend installing forged pistons and new stock rods (forged would be even better). Definitely install a GTE oil pump; it's a much higher flowing pump and you'll want it when you add oil cooler and turbo.
Later I would install upgraded injectors and swap in GTE electronics and upgraded fuel pump.
