Old 11-27-2009, 10:48 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fast seal View Post
I found on ebay a 2JZGTTE engine for $5000 dollars it says it comes from a 1996 toyota supra tt and comes with the following:
YOUR JDM 2JZGTTE COMES WITH FOLLOWING:
  • ENGINE
  • 6SPEED
  • WIRING HARNESS TO ECU
  • COMPUTER (ECU)
  • TWIN TURBOS
  • ALTERNATOR
  • AC COMPRESSOR
  • POWER STEERING
  • IGNITOR CHIP
  • INJECTORS,COILS ,FUEL RAIL,
  • INTAKE MANIFOLD ,
  • TURBO MANIFOLD
  • CLUTCH
  • FYLWHEEL
  • PRESSURE PLATE
so can anyone help me if this is a smart choice?
Agreed there isn't enough info...not even the mileage on the engine, or it's compression numbers???!!!
What would you be planning to put it into? For example, is it going to go into another '96 Supra TT chassis?
Life begins at 30psi.
