Old 11-25-2009, 07:58 PM   #1
Begin with checking for error codes. Then start looking for vacuum leaks; An intake leak would probably cause you to run worse after 2.5K and not before.
Check for diagnostic codes: http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Why was the car sitting for 10 years? Blown head gasket? If so, the bearings have probably eroded and you may have some significant rod knock.
The stock turbo begins spooling around 2K and all turbos spool faster if you're running rich (it's a tuning trick actually)... cooler air is denser and richer air is denser.
