Old 11-23-2009, 11:47 PM   #1
Here's a DIY on it making boost controllers with a couple weak diagrams on vacuum routing:
http://www.gusmahon.org/html/boostcontrol.htm
You can source vacuum from either the manifold or the turbo, sourcing from the turbo is the safer setup when you're not running a boost controller... it reduces surge, both heat and temp (this is of course not relevant when running any sort of boost controller).
