Old 11-22-2009, 05:05 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Best of luck with the comp. test, do you know anyone in the motor trade who could do the "sniff test" with an exhaust gas analyser in the rad top? Either that or a chemical "block test" would also be worth doing if possible...
150, 150, 150, 150, 150, 150... here's hoping...
Oh, and another thing to look out for at the back end is brake disc (or handbrake drum) warpage or sticking. Although if it was this you'd likely feel a pulse through the brake pedal on braking (or the handbrake lever, if applied just enough to slow the car while moving at about 30mph)
