Old 11-19-2009, 04:48 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Right, thought about it... Yep, perfect sense. The ct-12b is from the twin turbo then? I was under the impression that the turbo you were talking about was simply from a USDM 3.0 turbo but it's actually one of the units from the 2.5 TWIN-turbo isn't it?
In that case then I think you'll find very little problem with spool times or with the capacity of the compressor to produce sufficient boost for your engine (having effectively come from a 1250cc, 3cyl application). It's all in the interpretation see, If I'd known it was a tt blower I'd have kept my big yap shut (or simply put the last bit about posting back the results, speaking of which once you're up & running try & get a video on youtube or similar & let us know where to find it, I wanna see!!!).
