Old 11-18-2009, 07:18 PM   #3
I believe you posted in the wrong thread. EDIT: If you're referring to needing a sticky about the leaking valve cover seals it is the #1 sticky already... don't know how complete it is though, never read it myself.
Originally Posted by untweru View Post
First of all, many DOHC engines have spark plug well seals. This, however, is not the case on the 87-92 7M engine.
The 7M does have a plug galley seal/cover... the problem is that over the years the rubber's dried and usually rotted away and as such the only good it does is to filter out larger debris. Still, it's only a stopgap.
