Old 11-11-2009, 12:57 AM   #1
You need: Oil cooler (preferably a custom full-flow setup as the stocker is garbage), the same year engine harness and ECU as your car is HIGHLY recommended as the dash harness also has to match, clutch, drive shaft, intercooler and piping, ALL electronics (AFM, Igniter, coil packs), lines for the R154 clutch, motor mounts from your original engine if they are a different style, GTE fan and fan clutch are highly recommended.... I'm sure there are a few other things that I'm forgetting, I'll post back if I think of anything.
