Old 11-02-2009, 07:46 PM   #2
There is one spring with a nylon shaft in the center of each rocker. Pull the rocker slowly and they'll both remain in the rocker as at full extension the spring isn't long enough to push either from the rocker and there's suction present from the grease used to lubricate the two... as I said though "IF YOU'RE MECHANICALLY INCLINED" and I mean it... if you are then it's a piece of cake.
EDIT: I suppose I should further qualify that you need to be decent with medium-small parts.
