Old 11-01-2009, 05:39 PM   #6
Check all the usual suspects, vacuum leaks (use an aid to be sure you're not missing one: propane, brake cleaner...), timing, verify ALL of the vacuum routing, test the BPV to see it the diaphragm isn't split and creating a leak there.
