Old 10-31-2009, 11:09 PM   #1
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Two big things you'll have to deal with during this swap. You'll have to get a 2jz bellhousing for the w58 transmission if that's the trans you have. Then you'll have to do a wiring swap for the 2jz engine control system which isn't easy. I've always wanted to try to retrofitting the 7m engine control system to control a jz engine, but i haven't the time to try it.
This isn't counting w/e little things you'll need like clutch, flywheel, cooling system parts, and misc. sensors you'll need. Have fun with that.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
