Old 10-31-2009, 05:38 PM   #1
You cut it? Huh? Every speedo cable I've seen from Toyota was the right size to begin with. Why did you have to cut it and where did you get it? An 1/8" of an inch really should be enough to prevent it from mating with the speedo unless the sheath has been cut down too much and the cable is falling out of the green collar/endpiece.
