Old 10-23-2009, 10:58 PM   #12
89suprat
89suprat is on a distinguished road
thanks for some of those helpful hints, well all my vacuum lines are hooked up except for in the picture you can see that i dont have a bvsv with two vacuum ports, instead rather it has an electrical plug. the vacuum line has simply been directed to the charcoal canister from the port on the metal line coming out parallel to the intake. could this possibly be because it's a 91 engine? and also i haven't tested the wires but i assume they are operational even considering im using a stock ecu. and i apologize if it's a fuzzy picture shity camera.
89suprat is offline   Reply With Quote
