make sure to put brake fluid in the master brake cylinder and bleed it before you put it on the car...
most master brake cylinders come with a set of bolts to bleed it before installattion.
first time i done it put it on first... what a fuckin mess,
also i suggest when bleeding system after. put a rubber tube to go on your bleeder bolts on the calipers into a cup full of brake fluid.. that way there is room for "some error" and if the peddle is accidentally let off a bit, it will only suck up more fluid not oxygen...
wish you luck, i myself got a master brake cylinder for 75$ new
