Old 10-21-2009, 10:52 PM   #1
You can put it together for less if you shop around a bit. I've done a good amount of business with HPF in the past so the rep I usually dealt with gave me some good breaks on the pricing by matching and beating prices I found elsewhere... I don't know if you'll be able to do it quite as inexpensively as I did, but $450 to $500 should be doable.
On a side note, for those who are interested GR-2 does make an adjustable damper which is compatible with our front end... the front dampers for the MKIV fit. These are not a TEMS compatible damper, you have to adjust them yourself (from under the hood, IIRC).
Too bad you're not local, I'd let yu take mine for a spin so you really decide.
