Thread: Is this oil?
Old 10-21-2009, 01:48 AM   #3
Krem
You're just screaming for trouble... well, just in case, get used to downshifting and engine braking and make sure your E-brake is 100%.
I've had my brake light come on once, that's how I knew it was brake fluid... and I've added fluid to replace what I lost.. so hopefully she'll be ok till the 1st of the month.
Heh, I told you I had leaks and kinks to work out... I thought this car was in good condition when I bought it... just my luck, two weeks later it starts falling apart. My first car did the same... after two weeks, alternator went, then had to replace brakes, then alternator went twice more.. the last one actually made contact with my hood and made my car lunge and act like it was dying out... I popped the hood before it could set fire or melt the hood seriously... only made a small bubble in the hood. After this, the brake lines cracked on my way from Vegas to Salt Lake City... Stayed in St. George, Ut for the night... when I went out in the morning, brake fluid all over my wheel, tire and the ground. I was out of fluid completely. Had to drive that back to vegas at 40mph w/ hazards... outside the city limits, we hit traffic.. Had to use my gears and ebrake... it was scary and nerve wrecking, but managed to not hit anyone.. after that, I was done and got rid of it.
I used to do all the work on that car... and the alternator kept failing cause I had the amp for the speakers overloaded... It's been 10 yrs since then and I haven't needed to do auto work since... so I've lost my year and a half of autoshop skill from HS due to lack of practice. I'm also more of a learn by seeing and doing kinda person, so I'm trying to observe the repairs when possible and I try not to ask too many questions so they can do their jobs, but it's all I can do since I'm sure their garage won't let me work on it myself.. If I could afford an automotive trade school, I'd seriously consider it... but I can't even afford to fix my car once and for all.
