Old 10-16-2009, 01:52 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
Default You need the TSRM
Click this link to the TSRM on-line. Starting on page FI-23, there is the procedure to extract the codes from the ECM using a jumper wire and reading blinks on the 'Check Engine' light. Then, just look up the codes listed in the TSRM. Even if the light is now off, the codes are stored until the memory is cleared.
