Thread: R.i.p
Old 10-13-2009, 11:27 PM   #1
Krem
any assistance from insurance companies? that should help if available... and mine also has an oil leak or so I think... only seen the leak once on a span of two days when it was cold outside... after it warmed up again, no more leak... since... so I'm thinking prob somewhere pressure is escaping and when the oil thickens as it cools, it's pushed out from the oil pan pressure... However, the oil pressure when running is within specs... on the very low end, but still within specs... so I'm hoping she'll hang in there for another month till I can get another $500 to spend on dropping the suspension and engine... Good luck to you.. hope you find positive resolution soon..
