Old 10-13-2009, 11:21 PM   #1
mirage83
Get a shroud, new or used doesn't matter, probably someone on the board or boards has one they'd part with reasonably. The shroud's important as it helps direct airflow through the radiator rather than allowing it to flow around it (where it does little good in cooling your engine). That'll fix the hood-liner being chewed as well.
