Old 10-13-2009, 05:24 AM   #10
86.5 7MGE
86.5 7MGE's Avatar
So upon inspection of my system I notice that I do need to do a complete brake line flush due to the brake fluid looking like a dark brownish color in compared to a clear water color when it's fresh. I have also found a cracked line in my left rear side exposing the braided lines. So I'm just going to order some new Techna Fit performance brake lines all around. I also noticed on changing out my pads that they had some rust on the inside of it where it touches the rotor. This will be the last time I will be able to get my rotors resurfaced so next I'm going with the performance rotors. Eventually I'll be able to save up for a front and rear big brake kits; it's crazy how they cost as much as a high end turbo.
ID:	2432   Click image for larger version
ID:	2433   Click image for larger version
ID:	2434   Click image for larger version
ID:	2435   Click image for larger version
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
