Old 10-13-2009, 04:04 AM   #13
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by AAPSuprabuilder View Post
I just got done with that same issue on my 87, I replaced the head gasket had all new hoses installed, put a new water pump on and fan clutch. All to find out my radiator wasn't cooling to specification so when the car stopped the pressure was still in the system as the coolant was too hot. I HIGHLY recommend taking out the radiator, take it to a radiator shop and have them flow test it. The average cost is around $15.00. It may save you hundreds in the long run and either way you know for certain if it is or isn't good enough at cooling. As the radiator heats up the fins are supposed to disperse the heat although a Toyota that is older sometimes has their radiators deteriorate. the money you spend on getting it tested will easily pay for your time and frustration in the long run.
Thanks for the input I'll look into that, I was wanting to get an aluminum radiator any ways now I might have a reason to get it earlier than anticipated
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
