Old 09-23-2009, 11:36 PM   #19
Krem
Originally Posted by oregonjoe View Post
Put the fuel pump fuse back in and connected the spark coil. Set the distributor to half way and shut the door.
Key in – turn, it starts.
OIL pressure gauge climbs up to normal pressure. Enough for the night.
Where might I find the fuel pump fuse on the mk3? I'd rather check for this and make sure that's not my problem before I go replacing the fuel filter and/or pump.. also, is this fuse the same thing as the fuel pump relay (which I think is located above the right front wheel well just under the hood?)
Also, what is "normal" oil pressure... this is the first car I've owned where I have a guage for oil pressure and within the two weeks of driving the car, I've noticed it'll go up around 40 psi when I start her up cold... within a few minutes, she's down to 10~12 psi and will build up to 20~25 with engine use/revs... Does this sound normal? too low? Maybe there's something I can check for or do to help keep the pressure up a bit more? Looking at the TSRM, it sounds like i'm running at the minimal threshold for oil pressure, but I also think: "It's nat. aspired... not a turbo, so the pressure shouldn't be towards the high end." but I'm no mechanic... two yrs of HS auto shop (one 9th and other in 12th grade) over a decade ago, I'm not as sharp on the subject as I'd like to be.
