Old 09-23-2009, 12:48 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by InSvain View Post
...what i aslo meant to say was that a GTE engine is build with turbo`s so everything is already worn in the proper way and doesn`t need to much change to get more power out of it.
so less change = less work = less problems = less money spend
So you're saying the only difference between the 2jz-ge and the 2jz-gTe is that one gets worn out differently????
Life begins at 30psi.
