09-22-2009, 07:26 PM
#17
Spark Plugs
I then secured the Valve Covers and put 4 OIL PLUG washers on the No 3 valve covers with lots of RTV as they were leaking before the project. Installed the new plugs with Anti-Seize as the old plugs were real difficult to remove. I then took all the old plug wires apart and rebuilt them with new wire and ends. Was able to custom fit each wire so the length were perfect. It takes 16 feet exactly of bulk wire to make up all the plugs. At $30 for wire and ends – saved $50 from buying a pre made set and got YELLOW as well
