Thread
7MGE Engine rebuild
09-22-2009, 06:27 PM
7
oregonjoe
Drivers Side Electrical and Hoses 2
Before installing the Intake runner, you will need to route several lines through the runners BEFORE placing the intake on the head. Run the supply and return fuel lines, IAC Hose from the manifold, and water bypass hose through the runner.
The IAC Hose was tricky – it is an L shaped hose that connects to a nipple on the bottom of the Intake Manifold and runs up to the IAC. You can’t see the nipple once the manifold is installed so its much easier to locate and install it first.
oregonjoe
View Public Profile
Send a private message to oregonjoe
Find More Posts by oregonjoe
