Old 09-20-2009, 04:54 AM   #1
scaggsj
scaggsj's Avatar
Id check the water pump cause the impeller in side could be ate up and therefore not able to pump. I had this happen on a 98 dodge not a common problem but if the coolents never been changed and become acidic it could happen. Mainly cause you said theres no pressure in the upper hose another thing could be a bad thermostat I know you said it was changed but Ive had alot of brand new thermostats be bad from the get go. The pressure test is a good idea too.
1987 Supra 7MGE - Auto - Stock - White
Previoius Toyotas;
1992 Toyota Celica Gt, (Sold)
1988 Toyota Celica Alltrac Turbo (Died)
