Won't crank sometimes, push in clutch several times then it will start.
Suspect clutch sensor or security problem. its not battery cable or starter problem. If it is clutch sensor how can I disable this.The problem happens when the the engine is hot. My car always starts fine once the startede engages.It's that every now and then the starter does nothing.
