Old 09-08-2009, 12:20 AM   #1
ynnek
ynnek is on a distinguished road
Default Thanks for the replies
After doing some reading on this forum & some actual investigation, I realize I have a few more minor issues:
  • Stuck VSV valve, no heat
  • Climate control fan only works on Hi speed
  • Gear shifter is very loose
  • Hood & hatchback shocks need to be replaced
  • power antenna not working, maybe it is just not hooked up as there is a Pioneer head unit installed
  • Clunking noise when turning sharply
  • Needing an alignment, maybe due to the previous symptom
  • Rear transmission mount shot
  • Eratic speedometer cable
  • Driver seat has a lot of "slack" in it.
Well it looks as though I have my work cut out for me. I will get all of the minor things fixed, then have the dent pulled on the quater panel & have it painted back to the factory color. Stay tuned & I will update all of my progress.
ynnek is offline   Reply With Quote
