Old 09-04-2009, 04:59 AM   #2
Triggarise
Triggarise's Avatar
Triggarise is on a distinguished road
Originally Posted by top-tuner View Post
Well as you mentioned that the engine has an aftermarket
B.O.V vented outside the engine will get overfueled as
the B.O.V releases the exessive air !!!!
Does your engine have a M.A.F sensor ???
The only way to fix this is to recirle the B.O.V air back in the
intake tube by the air filter .
Or what i did is buy a P.C.V valve with 5/16 inch barb fitting
and put this inline with the vacuum line from the intake manifold
it helps a lot a the engine will no longer cut out .
GRT...
is there a step by step for this? im a little confused still
Triggarise is offline   Reply With Quote
