Old 09-02-2009, 06:18 AM   #12
btwilson86
Super Moderator
btwilson86's Avatar
Well, deflection should be any change in the resistance. A jump from an actual number to "0.L" (which I'm assuming is the infinite reading for your meter) would be a deflection in the reading.
So I have a question for you; after you adjust the TPS, do you take the 4 readings (as well as the 5th check where you make sure that between the VC-E2 terminals the resistance is between 4.25-8.25 kilo-ohms at all throttle positions) again? If not, then you might actually be putting it farther off of it's mark.
If you can't get it within spec, you might need to replace the TPS.
